  #1
Old April 23rd, 2006, 03:59 PM
ray j ray j is offline
Default 1980 75HP EVINRUDE LOSS OF POWER UNDER LOAD
1980 75hp Evinrude runs just fine on the hill but once under load just bogs down as if not getting gas. brought home and checked carbs. all looked clean.took out bottom screw on all three carbs and they were full of clean gas.just replaced plugs. i just bought new fuel tank and noticed i had not opened vent all they way. could this be the problem or could it be electrical in nature?
  #2
Old April 23rd, 2006, 06:55 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: 1980 75HP EVINRUDE LOSS OF POWER UNDER LOAD
Welcome Ray!Is this engine new to you? If it's new to you, had it been setting long before you got it?Always keep the fuel tank vent wide open. Although you did not have the vent wide open, I do not think this is the cause of the engine not making WOT.Have any idea when the carbs were last overhauled? Reason being, you really can't tell what's in the bowl without taking the carb apart.If the engine is new to you, take the time to do some tests. Compression and spark tests' are a must. Check the throttle plates are opening and closing fully and at the same time....you'll need to take the carb cover off to do this.Check your fuel lines are still pliable and good. Hard fuel lines can suck air at connection points.If you have no idea when the carbs have been last overhauled, I would recommend it. A lean running looper like yours could in time scuff the cylinder walls.Make sure the choke plate is opening all the way when the solenoid is deenergized.A service manual would help you a lot. OEM's are preferred because of the specific info they give on a given engine.Give us a little history on the engine and we'll see what we can do.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sudden power loss - 75HP Evinrude wolgemuthg Johnson & Evinrude Outboards 2 August 8th, 2005 07:09 PM
Power loss under load nraycroft Mercury & Mariner Outboards 2 September 5th, 2004 04:17 PM
1980 evinrude 70hp no power under load for the first few minutes dmaff Johnson & Evinrude Outboards 13 October 5th, 2003 04:09 PM
1997 Evinrude 115 Power Loss under load hornet Johnson & Evinrude Outboards 1 July 9th, 2003 08:49 AM
loss of power under load willinfla Johnson & Evinrude Outboards 2 April 9th, 2001 03:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
