  #1
Old April 18th, 2006, 05:35 PM
2ntow 2ntow is offline
Default Erratic idling on 2003 225 Evinrude
Sometimes during start-up, motor will start and immediately go to 3000 rpm, then not drop down to normal idle rpm. If I turn it off, then re-start, it will then run around 700-800 rpm. This problem also occurrs when pulling back on the throttle and going back into neutral, where the rpms will jump back up again. It appears that the throttle linkage is working fine when I remove the cover and check it. Any ideas on what to look for next? Could old spark plugs be causing the problem? Kind of at a loss on this one.Thanks for any suggestions on what to check.
  #2
Old April 18th, 2006, 07:03 PM
seahorse5 seahorse5 is offline
Default Re: Erratic idling on 2003 225 Evinrude
Your Evinrude is a DI model (direct injected) and any extra fuel that is introduced into the intake will make the motor rev up. Most likely the fuel pump diaphragm is leaking slightly or the vapor tank is overflowing and the excess is delivered to the intake manifold. A QUALIFIED tech has the know how and the manual and tools to fix this. Normally the motor would shut down and give a code 57 if the motor revs up while the throttle is closed.You can check the fuel pump for internal leakage by removing the pulse lines from it and seeing if there is any fuel residue in them.One other possibility is that the throttle position sensor (TPS) is loose or flakey, causing the "computer" to do weird things.
  #3
Old April 19th, 2006, 06:05 PM
Found the problem after thinking about it last night. Went back and checked the linkage to the intakes, and everything looked fine. Then I noticed that the linkage was not returning all the way back so the stop adjusmtent was up against the block. DUHHHHHH, throttle cable was removed last week, and I think one of my little helpers that likes to turn things made an adjustment to the black adjustment nut that controls the cable length! Re-adjusted it so it now goes all the way back, and motor idles normally again!Thanks, Seahorse, for the reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25 Evinrude idling problems Dale Feicke Johnson & Evinrude Outboards 2 May 30th, 2005 11:35 AM
Erratic 3 hp Evinrude Bill kubiak Johnson & Evinrude Outboards 5 July 20th, 2004 07:06 AM
evinrude idling problems TRANQUILLO Johnson & Evinrude Outboards 15 July 9th, 2003 05:12 PM
evinrude idling problems TRANQUILLO Johnson & Evinrude Outboards 0 July 7th, 2003 04:09 PM
1980 100 hp evinrude runs erratic dixieray Johnson & Evinrude Outboards 19 March 13th, 2002 12:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
