starter
odell
i have 1983 35hp johnson the starter will not pop up in fly wheel but starter runs :confused:
BoatBuoy
Re: starter
many times when the starter motor spins and the bendix fails to engage the flywheel, it is because the battery is not "hot" enough.
fireman57
Re: starter
If your battery is fully charged as BB suggests try spraying a little WD-40 on the shaft. If this works then lightly spray some very fine machine oil on it to keep it lubed.
Joe Reeves
Re: starter
Grease or regular oil will collect dirt resulting in a binding action that prevents the bendix gear from sprialing upwards.<br /><br />The light machine oil mentioned above is as heavy a oil that one should use. Also, if grease and dirt exists, the WD-40 mentioned will clean that away quickly.
