  #1
Old April 16th, 2006, 08:10 AM
rpf rpf is offline
Default 1987 Evinrude 70hp VRO compression
Hi,I have put a deposit on a 1987 boat with a 70hp VRO Evinrude. The mechanic informed me yesterday that the motor has the following compression readings:145 psi145 psi125 psiI see from previous messages that it is more important for each cylinder to be within 5-10% of one another. The Mechanic indicated that the cylinder wall had some scoring which is causing the 125-psi. He read that there is a bulletin on this motor with regards to this cylinder not being cold properly and for one hour of labour and a 15 dollar part that can be rectified and should prevent any further loss in compression and scoring in this cylinder. Should I be concerned as this is 16% of the other two and could this recommended fix prevent further damage? Or should I move on and look at other boatsÂ…Any help on this would be much appreciated.Cheers Ross
  #2
Old April 16th, 2006, 08:37 AM
OBJ's Avatar
OBJ OBJ is offline
Default Re: 1987 Evinrude 70hp VRO compression
Welcome Ross!I do not know of any bulletin about the lower cylinder running cold and a fix for the problem. There are a couple out that do address the heat sensor and relocating the telltale elbow. What part is the mechanic going to replace?My opinion on the engine is this....the damage is done and will not get better. If anything, it will get worse over time. Did the mechanic actually pull the head to look at the cylinders? Are the scores really scores or scuff marks from running the cylinder to lean? The three cylinder loopers are good engines for sure....but buying one with a known problem....well...if nothing else, I would try and get the price down on the engine.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old April 19th, 2006, 09:54 AM
rpf rpf is offline
Hi OBJ,Thanks for responding so quick.A couple of thingsÂ…I had the compression in reverse order (shows you how much I know) about motors. The compression from top to bottom is.125145145The mechanic said it is some sort of plug that he is putting in based on the bulletin. You are correct the damage is from running hot on the top. This fix will properly cool it.The Mechanic did not take the cylinder head off but confirmed that it is scored and not scuffed.Does this change your opinion?Sorry to miss lead you with the first information. Cheers, Ross
  #4
Old April 19th, 2006, 10:12 AM
R.Johnson R.Johnson is offline
As OBJ pointed out, it sounds like he will relocate the tell-tale elbow. I don't know how you would tell a score from a scuff with out removing the head. In my experience, a scored or scuffed cylinder will show a piston that will look even worse, once removed. It will not stop, and it won't get better. The only thing I know off that will restore compression is a wrench. I have had very little success with anything in a can.
  #5
Old April 20th, 2006, 02:32 AM
Wakeboarder Tom Wakeboarder Tom is offline
I agree with RJ above - the mechanic can do b****r all to fix this. Get a reduction in the price of the boat if you can. The only way of solving the reduction in compression is a rebore.You will find that the engine will not idle properly if the compression levels are different - we had the same problem on our 70. The cause was a packed up/intermittent VRO which starved oil to the fuel so be very careful about buying this. THe cause of your scoring may not be a simple overheating problem. The problem your mechanic is trying to solve is that occasionally this model engine can get an air lock in the waterjacket at the top of the block. Moving the telltale outlet to the top of the flat metal plate on the side of the block stops this from happening, although it is more likely to be something a bit more serious.It may be cheaper in the long run to lose the deposit and find another boat??!
  #6
Old May 1st, 2006, 03:56 PM
rpf rpf is offline
Hi RJ & Wakeboarder Tom,Sorry for the delay between messages but I was in Europe on business and never seem to have enough time....Thanks for all the advice. I am moving on to the next situation and look forward to sound advice such as yours in my future endevours.Thanks again,Cheers, Ross
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 1987 110 HP Compression w2much Johnson & Evinrude Outboards 5 June 24th, 2005 12:28 AM
Compression 1987 Evinrude XP 150 muchco Johnson & Evinrude Outboards 10 June 16th, 2005 01:05 PM
1989 70HP EVINRUDE COMPRESSION PROFESSIO Johnson & Evinrude Outboards 9 May 26th, 2005 09:56 AM
1987 evinrude 70hp cdoody71 Johnson & Evinrude Outboards 5 May 1st, 2005 10:54 AM
1987 Evinrude 70HP Lost top end mncafik Johnson & Evinrude Outboards 3 April 29th, 2005 06:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
