I'm rebuilding a '92 60 Hp evinrude for a friend. He burn a piston out so I had that cylinder bored .020 over. All of the rings and bearings were replaced . The compression checks as follows #1(new piston)120, #2 110, and #3 110. Is this acceptable? The other two cylinders were honed and as I said new rings were installed.<br />Also, can someone tell me how a leak test is actually done? I've heard this is a better way to judge the condition of the cylinders and seals. I was just wondering if there is a way to make one of these setups.<br />Thanks
