tulsaman48
- Oct 21, 2005
- 1
I just bought this 76 charger with a 76 85hp evinrude with tilt trim. my question; i went to change the fluid it was cotaminated it was pinkish white. I have no manuel to go by, what kind of fluid do i use and what position should the motor be in to refill it and how much should i put in it. i moved the engine up and down manualy to get all the old fluid out but not sure how i put it back in. there is a screw on lower right side at bottom a smaller screw at very bottom and and a flush screw in the middle of the upper part of the tilt trim does any of this make any since your help is appriciated.<br /><br />Ricky
