Hello,<br /><br />I was hoping someone could help with a problem I'm having with a newly acquired '96 150hp Johnson Ocean Runner. The motor will not tilt using either the main controls or the trailering switches.<br />I can hear the tilt motor running when I activate the switches, but no movement. <br />Also, the manual release screw will not budge, so I'm not able to get a look at the tilt assembly.<br />Is there another way to get the motor up into the trailering position?<br /><br />Thanks in advance for any advice.
