76' 15 Johnson misfires
cracks214
I started my engine for the first time in 3 mo. and the engine began misfiring immediately.Misfiring from idle to WOT.The last time it ran good and ran the fuel out when finished.I have since put in a carb kit,changed plugs,checked for loose wires,de-carbed(previously),checked with another tank and fuel hose.I would appreciate any suggestions for this problem.
WillyBWright
Re: 76' 15 Johnson misfires
Points and condensers. :) <br /><br />If you keep the motor on a concrete floor, don't. ;)
MCM
Rope start right? I looked at your first post. ;) <br /><br />How's the spark, strong, blue & snappy or yellow & kinda weak?<br /><br />I think WillyB's heading the right direction.<br /><br />This article is a must I think for anyone with a 9.9/15 hp from '74 on. Check it out<br /><br /> http://www.pugetsoundanglers.org/Fishing Info/Johnson 9.9_15.htm
cracks214
I will check the points and condensers next.Could it be the coilsand if so how can I check them with a digital multimeter?
Joe Reeves
If the misfiring is more like the engine is spitting back thru the carburetor, and the slow speed adjustment needle valve has little or no effect rather than actually losing spark momentarily such as an ignition breakup, that is usually due to a fouled carburetor.<br /><br />Did you check and manually clean the small jet that is located in the extreme bottom nozzle portion of the carburetor body? If not, it would be a good idea to do so.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br />(J. Reeves)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /> <br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /> <br />Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.<br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
