Re: No RPM's in gear (CD-19)
Welcome to Iboats, satterly! If you want to fix up one of your posts, just click the "Edit Post" icon.<br /><br />Make sure both sparks can jump about a 3/8" gap. There's a common problem where they'll jump a spark plug gap just fine (nice & hot) but not a wider one. Also, closely examine the spark plug wires for any cracks, etc.<br /><br />If that all checks out, try pumping the primer bulb. Does it make it run better/worse/no different?<br /><br />Revving the engine in neutral is really bad for it.
