Have 15hp Rude Fastwin with shift lever problem. The adjusting lever behind the shift lever is broken. How can I find a replacement part? Is it possible to just reinstall the shift lever and clamp it extra tight? If I get replacement part do I have to pull power head off lower motor cover assembly to replace part? I have a similar parts engine but shift lever mechanism is different. References for those patient enough to help me: Clymer Old Outboard Service Manual Volume 1 page 205 figure OMC7-16, the broken part is part number 2. The parts engine seems to be the one illustrated on page 206, figure OMC7-17. Are the shift lever mechanisms interchangeable? Is this a winter project?<br /><br />Appreciate any help you guys can give.<br /><br />Thanks in advance
