John Herzhaft
- Oct 9, 2005
- 3
Motor will not idle, 2 botton cylinders seem to not be getting fuel, but show oil on plugs.Have disassembled & cleaned carbs & all was good. Motor will run out fairly good @ top end but then stall out & seem to locked up, but quickly starts back up, I have sprayed gas into carb @ idle but made no diff.Have 125 PSI compression @ all 4 cyl. How do I know if I have a reed problem or not. Isue is only w/ bottom 2 cylinders
