  #1
Old April 7th, 2006, 04:11 PM
huntingjustinlouise huntingjustinlouise is offline
Default 1979 Evinrude 70 surge in power/loss of power
I have a 1979 70hp Evinrude on a 17' 1991 Tracker Pro Deep V. Occasionally the motor runs great all day.Most of the time the motor will run good then suddenly either die if in idle or lose power if running at speed.Ive also noticed the fuel bulb goes soft .I've replaced that line with no luck.If I squeeze the bulb sometimes it will stay running other times not. I know nothing about motors and any help would be most appreciated Thank you Justin
  #2
Old April 7th, 2006, 04:27 PM
ezeke ezeke is offline
Default Re: 1979 Evinrude 70 surge in power/loss of power
Are you using a portable fuel tank, and if so, could you describe it, please? It sounds as though you are not getting air into the fuel tank through whatever vent it has.
  #3
Old April 8th, 2006, 04:45 PM
Thanks for helping. The fuel tank is a rectangular 15 gallon permanent installation.The hose from the tank to the motor is the standard typ removeable hose like on most portable tanks use. ive replaced it once
  #4
Old April 8th, 2006, 04:51 PM
I forgot something important the motor only acts up when under load. When I run it with muffs and a hose itworks fine.
  #5
Old April 8th, 2006, 05:04 PM
Next time the motor quits, get to the cylinder head quickly and feel for overheating.The pickup in the tank may be blocked and the vent could be blocked. I think running on a portable tank for a day would eliminate those concerns. Check to see if the vent screen for the tank has corroded. Just heard about a guy here who pumped and pulled a 100 gallon tank, only to find that the screen was blocked on his vent. Could be the power pack. Some will cut out when they are heated up. You can try to check that with a hair dryer blowing on the pack to see if it cuts out.You will also want to clean the ground wires on the coils and check all of the other wiring from the power pack to the spark plugs.
  #6
Old April 8th, 2006, 05:26 PM
Silvertip Silvertip is offline
Primer bulbs will not stay hard after the engine is running. Fuel merely passes through it by suction -- not pressure. The bulb must not collapse however. If it does there is a restriction between the pickup in the tank and the bulb.
  #7
Old April 8th, 2006, 05:36 PM
Thanks I will try these suggestions this week and let you know thanks again Justin
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Mercury 2.5L, 200 XRI Model 750 Power Surge/Loss at 1500 rpm KrisE Mercury & Mariner Outboards 3 April 9th, 2009 12:32 PM
1979 Evinrude 140 Power loss.......need suggestions please. Theoutdoorsman Johnson & Evinrude Outboards 46 August 23rd, 2006 12:25 AM
Loss of power - 1979 Evinrude 15 hp tashasdaddy Johnson & Evinrude Outboards 0 July 3rd, 2006 12:12 PM
1979 200HP EVINRUDE POWER LOSS imported_steven Mercury & Mariner Outboards 1 June 25th, 2006 03:45 PM
1979 Evinrude 100 HP Intermittant Power Loss Frank James Johnson & Evinrude Outboards 4 September 7th, 2004 06:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
