I bought a boat with a 6hp 69 Johnson outboard about three years ago. Been using it in the summer. Today when I went to start it in a barrel to run some stabilized gas into the carb, The motor was a little stiff, but it started. I got no water coming from the pee hole, so I guess it's time for a new water pump. Is it possible that the stiffness could be due to the cooler weather we are having now, or should I be looking at some other problem? marvxyz
