elwilliams13
- Jul 4, 2003
- 137
1991 evinrude 225. Went out on the water when I was running WOT. Noticed my instruments on the dash had all zeroed out(no power.) Then engine began to lose rpm. Upon investigation found that my battery lug had popped off. Reattached it and could not rev up past 2000-2500 rpm. Got home and put it on the muffs ran good. After 5min had no spark on 1,3,5 cylinder. Checked the shift interupter and it was working properly. My question is could something have burned up from losing my battery connection or is the shift switch shorting out when it heats up? I'm stumped.
