marcysibyll
- Jul 30, 2005
- 66
The 1959 18 hp FastTwin w/ 20 hp power head refuses to fire. Have the adj screws at the start point- HI speed 1 turn out, low 1 1/2 out. Got choke linkage hooked up correctly, got spark and compression. <br />Float was set at right hight, level with carb body. <br />Primer bulb is pumped till hard. <br /><br />Going to pull carb again and check it out. <br /><br />Any advixe will be appreciated
