74 Evinrude Jumps out of gear
Dale Kelly
I have a 40 horse evinrude. It ran fine a week ago. Today before leaving for the lake I disconnected the throttle cable and the shift cable was going to lubricate them but didn't have right lub. I reconnected the cables and went for the water. On the first take off at half throttle it jumped out of gear.I throttled up again same thing happened. I was wondering if something in the shifting assembly came loose.I'm certain I reconnected them properly. I've had this motor for 6 years I just ordered the manual! Didn't need it till today!!Any suggestions?
fireman57
Re: 74 Evinrude Jumps out of gear
You probably just need to readjust your cable. Try shifting it manually and see if it stays in gear. you might need to take a buddy along for this.
Dale Kelly
We tried manually shifting with the shift cable disconnected it did not work. I need to know if I should hold the shift arm forward while throttling? Any suggestions? Thanks
