  #1
Old March 29th, 2006, 06:27 AM
Homemadeboatowner Homemadeboatowner is offline
Default 62' Evinrude Selectric Lark IV Wont turn off when you turn off ignition
I have a 62' Evinrude Selectric Lark IV and it starts up fine and i just recently replaced the control cable and now it idles fine when it starts up. However when i go to turn off the ignition it just stays on. I can take the key out and everything still runs. IS there a wire that isnt working right. I dont know much about outboards and this is my first boat. I need to be able to turn off the engine without having to choke it. How should i go about troubleshooting this? Ive read a little and the color wires that i have coming from my ignition are not standard. I have a red, blue, black and gray. What should i do at this point to try and diagnose a problem. Is there a work around i could try. Like putting in a kill switch somewhere? Please advise. Thank you
  #2
Old March 29th, 2006, 06:59 AM
Paul Moir Paul Moir is offline
Default Re: 62' Evinrude Selectric Lark IV Wont turn off when you turn off ignition
Welcome to Iboats, Homemadeboatowner!You're going to have do do some tracing. The kill switch circuit works by connecting the two points in the outboard's ignition system together, which shorts both them out and kills spark. The wires are the two small black ones comeing from up underneath the flywheel, and should ultimately connect to the two terminals labled "M" on the keyswitch. Unless you have the wrong keyswitch.Along the way there's a few splices where they connect into the vaccum cutout switch and a few disconnects. Here's some schematics:40hp schematic: http://www.shareaproject.com/fullImages/2627.jpg Here's a 28hp schematic I drew. It's a little more clear around the ignition switch: http://www.files.bz/files/3414/28schematic.PDF Once you confirm all the wiring is in place and connected properly, try manually shorting the two magneto leads together at the keyswitch to determine if the keyswitch itself is bad. Careful though, with the engine running those lines bite.Never ever let +12v on those wires. The battery electrical system has absolutely nothing to do with the ignition system.Hope that helps!
  #3
Old March 29th, 2006, 10:00 AM
Paul, Thank you so much for this information. It is exactly what i was looking for! I will troubleshoot this tonight and will let you know how it turned out. Sorry i didnt post it was the 40hp but luckily i got someone who covered all basis. Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Engine wont turn off tigerking Johnson & Evinrude Outboards 0 May 21st, 2006 03:48 PM
33HP Evinrude, engine wont turn, need advice meneermalik Johnson & Evinrude Outboards 5 March 29th, 2006 06:50 PM
99 225 mercury, can turn flywheel one turn then it stops HELP! jsmith55 Mercury & Mariner Outboards 5 April 29th, 2003 08:24 AM
evinrude 70hp 69 model wont turn over kandi2au Johnson & Evinrude Outboards 7 December 26th, 2002 09:24 AM
starter wont turn viperman1 Mercury & Mariner Outboards 4 August 18th, 2002 07:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
