marcysibyll
- Jul 30, 2005
- 66
Got the throttle working smooth- Had the ring that the mag plate screws to in upside down. Put bevel side up, per OMC mechanic and wala- smooth throttle. <br />Adj screws worked loost, so new packing and dissambeled the carb. Clean inside- ran carb cleaner thru all passages, blew out w/ compressed air. Put everything back.<br />Started with the hi speed adj 1 turn out and low speed 1 1/2 out. <br />Will not start. Coughed a couple of tiomes, but no run. <br />Got spark and compression- Should I be trying the adj screws at a different setting to get up and running?
