Fl_Richard
- Jan 21, 2005
- 1,428
I have twin '95 V6 150 loopers.<br /><br />The port motor has a rattle at certain RPM's. (So does my transom door) Sometimes it's hard to tell where the sound comes from. <br /><br />Yesterday while out I knew I was hearing a rattle so I took of the cover, let the little lady drive and I went back for a listen. It seemd like the top port cyl was where the rattle was most pronounced. But the motor is really loud without a cover @ 3500-4000 turns.<br /><br />I took a 23 mile trip (Each way) up to our friends house and back with no problems. The noise is typically in the mid RPM range. Runs like a bitc@ at wide open, no knocking or "bad" sounds. Just more of a rattle at about the same volume as my transom doors it's slide bolt when it rattles ... You know just enough that's it's annoying.<br /><br />Any guesses???<br /><br />Many thanks <br /><br />Richard
