i have a 1989 evinrude 110 picked up used not really running. replaced a piston and sleeve. new gaskets. cleaned and rebuilt the carb.'s checked the float leavel, with the omc. float gauge. placed in a test cell and ran it 6 hours breakin time (no-load) checked timing to 26 deg.(two deg. retarded from omc spec.)at this point it runs great. when i place a load on the engine (in the boat on the lake) i lose a cyl. at times it's intermiting. checked compresion 110, 115, 120, 120. At the tmes of the load engine and lost cyl. I've seen excessive fuel being dumped into the carb bores. and driping under the floats. removed the card.'s rechecked the float leavel, checked the float to see that they float. checked to see if the needle shuts off the fuel into the carb by inverting carb. checks good. reinstalled, the same thing again excessive fuel in bore,( u can really see it dumping a spray of fuel.) and a driping. I know i'm losing the cyl. due to to much fuel, but my question is could the vro pump be causeing to high a fuel pressure over riding the the needle? all jets are in place and there is on place for a pull-over jet (located in the center of the carb venture). i have even tried to set the float shallow to shut off early. no help. i do not have the oil enjection in a tank nor pluged (open line). oil is mixed in gas for now. when it is hiting on all cyl. the engine has run for ten minutes. or has shut off after running. and another time the baot was heading into the wind, when it did pick up the cyl.no i didn't look to see if there was still a drip. but i didn't see execessive gas being dumped into the bores.
