Re: Starter not working 50% of the time
Update: Ok, I took the engine cover off and listened. When I turned the key, I could hear something click on the starter, but the starter didn't spin. Tried this several times. So then, by hand, I turned the flywheel, and manually turned the starter gear. Then I turned the key and WALA it started fine. Could this isue just be a lubrication problem? Am I supposed to lube the starter shaft? If so, what do I use to lubricate it?<br /><br />Thanks for the help!
