Switch that detects motor in the down position
JBuff
Where do the wires get connected that lead from the switch that detects motor in the down position. I have a 1980 150hp evinrude.
Walker
Re: Switch that detects motor in the down position
Not sure which switch you are talking about. There is a tilt limit switch that stops your motor from getting tilted up too far. Those wires will be blue with white strip and they connect to the same color wires coming out of your tilt solenoid block. <br />the only other thing down there on your tilt/trim area of the motor is the trim guage sensor and those wire go up to you trim guage
