Mike Giglio
- Jul 25, 2005
- 33
I bought a 1972 65 hp johnson on ebay last week and put my 65 hp evinrude lower unit on it. The motor looked pretty clean and was running very well for about two hours . It idled great and had plenty of power. Then I noticed a slight loss in power but it was rectified by throttling. On the way in I lost all my high speed. I noticed the primer bulb was low and when i pumped it up it wouldnt stay hard and the boat stayed at max 10 knots. I'm wondering if the fuel pump may be bad or if dirty carbs could cause the ball pressure to drop. My tank is new and so is the ball and tank fitting. If I do clean the carbs up, I'm affraid to mess with the low speed needle. Everything was running so good i'm affraid the mess it up. Is it likely that the carbs are dirty if the motor ran flawlessly for the first hour? I have a spare set of rebuilt carbs from my other motor but the adjustments are all out of whack on them. They are clean though. Anyone know what the low speed needles should be set at for a 72 3 cyl Johnson. Can the low speed needles and those seats be removed for cleaning and damaging the seats or is it better to change the seats altogether. S-inc-e- -nmy problem is a fuel starving problem and not a low spped problem should <br />I just clean the float bowls and main jets. Thanks
