'62 johnson 40 hp spark advance problem
john cockburn
spring and connecting mechanism between throttle control and spark advance/armature have fallen apart. Is anyone aware of a schematic that depicts how this system is assembled...It doesnt appear to be covered in Seloc
rolmops
Re: '62 johnson 40 hp spark advance problem
Go to chapter 5 page 18 and see a full drawing.Then go to 5-26,27,and 28 to see the adjustments
john cockburn
Thanks for that...What I also think I need is some way to connect the drawing on 3-49 top right,specifically the spring connection details on the top of the throttle lever, to the follower on 5-18, bottom left...
Paul Moir
Here's a couple. These are a little dated so yours may be slightly different:<br /> Click here.<br /> <br />From my 28hp<br /> <br />I was in your same shoes a few years ago. Spent at least a couple days scratching my head over that spring. And quite a bit of time with the Seloc manual & magnifying glass on 5-26, etc. Then I found Iboats. :)
