pinto 21629
- Aug 18, 2003
- 99
i have a 1960 johnson super sea horse 40hp/rds 22 well it has the compression relief valve head it keeps blowing the gasket on the top cover i have put a new one in three times in the past year i even used high temp rtv sealent blowed the rtv all the way out last saturday i went out fishing and it blowed i took the cover off the motor and it was spitting water out the side of the small cover and when i looked at it looked like the cover was warped out where the water was coming out but that was right after i turned the motor off still hot from runningi know the warped spot is why the gasket is blowing but how can i fix it and i dont know if i will be able to find a new cover if it damaged hard to find motor in my area because the gaskets i had to go to a auto store and buy gasket stuff and cut out my owne because the boat store where i got my head gasket/carb kit.....said can no longer get and can i use jb weld to seal the covers if they are warped and cant find new ones im tired of changing gaskets every time i go fishing ?????? HELP PLEASE
