firstboat25
- Sep 2, 2005
- 98
Well here we go again <br />To all that helped with the lower gear oil draining and filling thank you that probelm was solved. Now onto this <br /> Boat went into the water tonight and after 20 mins of trying to get it running it finally started as soon as I would put it in gear and give it gas it would stall SO I took the air cover off and noticed that the flaps in the carb seemed to be opening to late but when I would open them by hand with the linkage it would still stall so I would give it a shot of either and she would take off but I had to have my friend drive so I could hold the carbs open with the linkage as soon as I would let go over it the engine would boug down and stall <br /> what would be causing this and why would the either help <br />also if engine would stall it was sometimes a pain to get tunning again <br /> Please help <br />Thank you guys you are the best
