Inconsistent high speed
Alpine high
I have a 1957 3 hp Johnson Seahorse OB motor that I bought recently. It hasn't been run for quite a few years. I changed plugs, saw no varnish in the carb. bowl, and made sure the float worked well. It starts very easily. My problem is that when I give it full throttle, it seems like it is running on one cylinder for a while and then it sputters a couple of times, and then kicks into full speed or it seems that the other cylinder engages and it runs great. It doesn't drop back to the slower speed while at full throttle. When I turn down the throttle, it sometimes reverts back to the one cylinder syndrome when I go to high throttle again. Any idea how to cure this problem?
R.Johnson
Re: Inconsistent high speed
Those old plug wire's could be shorting to the mag. plate on the under side.
Xcusme
Welcome to iboats! ;) <br /><br />Sounds like you might be dropping a cylinder at higher rpm's. This is not uncommon for older motors with bad coils. A bad coil can short to ground or a winding go open when they get hot. A service manual is a must at this point. Parts shouldn't be a problem.
Alpine high
Do I need a special puller to remove the flywheel to get access to change the spark plug wires?
Paul Moir
I like to use one (an automotive harmonic balancer puller and 3 1/4"-tpi bolts works well) but it's not strictly necessary for the 3hp. You can use the "lift and hammer" method. Have a look here:<br /> Click here for Tom Travis' site <br />If you replace the plug wires, make sure you replace them with metal core wires. You have to use 7mm for it to fit the coils. If yours are cracked, you can get replacement igniton coils from Iboats or napa autoparts (18-5181) or from your local dealer (different p/n).
