I have a 75 115 V4 that was running great yesterday. I went to start it today and it won't start. It is getting fuel but no spark I was wondering if there is a fuse in the ign., throttle controls or something I could check.
When you say won't start do you mean it won't even turn over or it turns fine but will not start? Does he have a kill switch hooked up to a safety lanyard? If he does make sure that it is in place. There is probably a 20 amp fuse on the port side (I believe) of the engine. If it is blown you will need to find out why. Possible short in the primer/choke solenoid or other places. If it blows again check and clean all electrical connections starting from the battery.
