  #1
Old March 8th, 2006, 06:24 PM
jjdm100 jjdm100 is offline
Default 35 hp Evinrude Drain screw
I pulled the lower unit drain screw and drained my gear oil. Then I went to reinsert the drain screw and it will not go in. There is a piece of metal in the way. It looks like it moves when I change from Neutral to Forwardto Reverse. I can not get the gear oil drin screw back in. What is going on? What can I do to fix it? (The drain screw is about 1/2" of threads then a 3/4" smooth shaft on the end of it.) Is that normal, too?Thank you for your help.
  #2
Old March 8th, 2006, 06:30 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: 35 hp Evinrude Drain screw
You pulled the wrong screw Adam. The screw you pulled holds the shift yoke in place. See if you can fiddle around with the gear shift lever and get the holes to line back up. The drain plug screw is the large one kinda under neath the gear case.EDIT: If you can lay the motor on it's side, that would help.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old March 8th, 2006, 06:32 PM
Thank you! Oops! : )
  #4
Old March 8th, 2006, 10:42 PM
byacey byacey is offline
Be careful not to overtighten when re-installing. It's easy to strip the threads on the housing. The one I have - the threads were all but gone when I got it. Rather than fool around with helicoils, I re-tapped for 5/16 NF, and machined a stainless steel Allen head capscrew to the right diameter and length for the pivot.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OMC Cobra Water Pump Drain Screw ? Lark40 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 August 1st, 2009 11:04 PM
Stuck gear oil drain screw on lower leg bluegothic13 Force & Chrysler Outboards 8 June 19th, 2006 10:56 AM
Drain/fill screw gaskets - different??? CharlesW Johnson & Evinrude Outboards 2 September 23rd, 2003 06:01 PM
Float bowl drain screw question miguel agullo Mercury & Mariner Outboards 4 June 27th, 2002 11:14 AM
oil drain/fill/level screw replacements greggimlick Johnson & Evinrude Outboards 0 May 21st, 2002 08:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
