  #1
Old March 5th, 2006, 07:40 AM
Ownsbud56 Ownsbud56 is offline
Default 1959? 10HP Evinrude Shifter and Prop Repair
I don't know if the year is correct on this motor.The model and serial #'s are 10018/12512. The owner says the shift lever is broken but does shift back and forth between gears. I guess this to be just a parts repair/replacement? He also states that the prop is in good shape but needs replaced because the rubber inside the prop slips. Is the problem he speaks of repairable or will a new prop have to be acquired? Other than that are the motors of this style/model/year worth repairing/restoring? I just want to use it as a runner on a 12FT Flatboat! Thank you for your time and any information will be appreciated! Ownsbud56
  #2
Old March 5th, 2006, 07:42 AM
Default Re: 1959? 10HP Evinrude Shifter and Prop Repair
I forgot to add that it is a 10HP Evinrude Sportwin Golden Jubilee model. Thanks! Ownsbud
  #3
Old March 5th, 2006, 07:50 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
That would be a wonderful motor for that boat. When they run, they run nice! You're correct about the year and Hp. Sounds like the shift lever alongside the hood broke? Common. It shouldn't be too hard to locate a used one, athough it may not paint match. Mix gas/oil at 24:1. Points gap .020", Champion J6C sparkplug gapped .030", Low Speed jet (top of carb) about 1 turn out, High Speed (bottom of carb) bout 3/4 turn out (ballpark settings). The prop can be rehubbed, but a new one would be very little more $$.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old March 5th, 2006, 08:17 AM
DHPMARINE DHPMARINE is offline
Generally these props don't slip,but the drive (shear) pin could be bad.Pull the prop and check. To change the shift handle I think you'll end up removing the powerhead to get at the linkage.Not the end of the world,but a bit costly if you have to pay a shop to do it.I would not buy an engine without a lake test,as well as spark and compression test.DHP
  #5
Old March 11th, 2006, 03:03 AM
Thank you for the information! The motor sold before I had a chance to look at it. Thanks again! Ownsbud
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pressure tank and carb 1959 10hp smeltjr Johnson & Evinrude Outboards 3 June 19th, 2005 05:35 PM
Carb problems w/ a 1959 10hp evinrude kuziak123 Johnson & Evinrude Outboards 3 May 12th, 2005 11:22 AM
1959 QD20 10hp-can I revive it? motordummy Johnson & Evinrude Outboards 5 November 30th, 2003 10:59 AM
1959 Johnson 5.5 HP Gas and shifter problem iflycy Johnson & Evinrude Outboards 5 June 30th, 2002 08:25 PM
1959 Johnson 5.5 HP Gas and shifter problem iflycy Johnson & Evinrude Outboards 0 June 30th, 2002 06:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
