Re: Evinrude 33HP throttle problems
When you advance the throttle (engine off and set in forward - you may have to rotate the flywheel a bit for it to engage) you should see the plate up underneath the flywheel turn, and simultaneously see the throttle valve on the carb open (as actuated by a roller that follows a cam on the plate beneath the flywheel. Eventually the plate should stop turning, caused by a stop near where the spark plug wires come out of that. After that, a linkage on the throttle arm should take over and open the carb's throttle valve the rest of the way.<br /><br />So, what part of that picture isn't happening here?
