  #1
Old March 4th, 2006, 09:00 AM
Manduchi Manduchi is offline
Default 89 Evinrude XP150 clicking out of gear???
LOOoong time lurker, new member. I bought this '79 Ranger 1850VS last month. It has an 89 XP150 Evinrude on it. It was last tagged for 2003, so I am assuming it hasnt been used in a while. On my first trip to the lake I noticed a problem. Once in a while when I am traveling at low speed..."idle" it will start making a loud click sound. I beleive its trying to pop out of gear. I can run that exact same speed when throttling down and not have any problems. If I go from neutrel to idle forward it does it about 50% of the time. Now before you all tell me I must not be giving it enough throttle, I assure you I am. Its my 3rd boat. I never had this problem before. The only way I can keep it from happening is to go to 2000 rpm then pull back to "Idle forward". "I think this tends to un-nerve people at the docks" I get alot of dirty looks? Im wondering, is this the shift dog? I am kind of leaning more towards some kind of linkage being out of adjustment? Im not really sure how to check??? I dont even know if there is a simple way to adjust that??? Can any one help me?? Also, does any one use hydro foils on there bass boat? Unless I am doing 20 mph my bow is pointed at Jupiter. Im afraid Im going to pancake some one because I cant see infront of me. Any suggestions?
  #2
Old March 4th, 2006, 10:06 AM
gatorred gatorred is offline
Default Re: 89 Evinrude XP150 clicking out of gear???
pull prop off see it it make's sound when truned by hand, check slop in shaft short of tearing it apart to check dog i had old 40 just flip dog over or clean it up only if gear isn't messed up where dog ride's in it,i sean the gear messed up there too.
  #3
Old March 4th, 2006, 02:22 PM
Walker Walker is offline
It very well could be your linkage out of adjustment. It could also be the shift rod height isn't set right. To check your shift linkage take the shift cable loose at the motor and shift the motor by hand. If it stays in gear without any clicking then you may have found the problem. Put the shift linkage in neutral by hand and put your controls in neutral. Adjust the trunion on the shift cable so the cable ends fits the shift linkage in that position. See if it works now.
  #4
Old March 4th, 2006, 02:31 PM
Ok, I will get to it in a couple days. Its kind of cold and dreary right now.
  #5
Old March 9th, 2006, 08:58 PM
Yep, It was the linkage...... Thanks for the help. I was worried for a while.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Evinrude XP150 muchco Non-Repair Outboard Discussions 8 July 2nd, 2005 06:44 PM
Mercruiser outdrive clicking in gear homealone Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 April 10th, 2004 11:46 AM
Value of 1988 Evinrude XP150? duncel Non-Repair Outboard Discussions 2 November 24th, 2003 03:04 PM
1990 evinrude xp150 Toby S. Johnson & Evinrude Outboards 2 May 2nd, 2003 05:31 PM
Gear shift problems / clicking noise txrdb Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 23rd, 2002 11:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
