I removed the intake manifold and found that it is missing the leaf base. The manual says that there should be<br />1. intake manifold<br />2. gasket<br />3. leaf base<br />4. gasket<br />5. leaf assembly (3)<br /><br />In my (working) motor 2,3 are missing, leaves are attached directly to the manifold with one gasket. Is it OK (just different modification)? Should I get the base and another gasket? Please advise. Thank you.
