martinphantom
- Jul 12, 2005
- 47
86 johnson 25 hp tiller-adjusted cam roller-checked compression, 125 and 125-installed carb kit(pulled welch plugs)-low speed adj is't right though, starts at 1 1/2 turns out, but increases rpms when turned in, dies when turned out-all new fuel lines-checked screen on fuel pump-new plugs gapped at 40k-poor low speed performance(almost seems to be running on one cylinder)-runs great at WOT and idles ok,light shake. Sprayed cleaner degreaser on engine and loosened up a sticky throttle(haven't had it out since). Did a decarb-cleaned up a lot. Any suggestions as to what to try next?
