Tested my '64 40HP Evinrude Big TWIN, and still am experiencing hesitation and bogging while approaching and near wide open throttle.<br /><br />It'll idle around at low speed just fine indefinately, responds quite good (as compared to earlier) right out of the hole.<br /><br />BUT, as after it planes out and runs a bit, it just bogs way down, then after a moment it'll either catch back up on it's own, or I'll idle back and to match the reduced RPM's and fuel need.<br /><br />I suspected the carb float adjustment to be at fault (the carb was just cleaned and rebuilt)...I didn't mess w/ the needle adjustment, figuring that was only applicable to low idle which runs fine. The first time I took it out, this bogging near WOT happened w/in 2-5 seconds.<br /><br />So, I took the carb apart to reinspect the float...it looked like it was nearly right, but, just to be sure (per the manual's guidance) I made very certain to set the float itself, level w/ the body/bowl.<br /><br />Put everything back together and on the water, and now, though it runs much better, it still will do basically the same thing, but this time not as bad a loss in power, and after about 20-30 seconds, not 2. It recovers more quickly...but nevertheless, I know it's still not right and this is something I'd like to get right before towing people.<br /><br />It responds as though it's a fuel delivery problem...things are clean, bulb firm, plugs cleaned, gas is two weeks old.<br /><br />What's the next plan of attack?<br /><br />Should I just raise the float a bit beyond level and hope that permits enough fuel to remain in the carb bowl?<br /><br />Beofore the carb rebuild, when I primed w/ the bulb, after it got hard, it would squeeze fuel past the needle, as the float wasn't set properly to close it...despite that improper adjustment before, the motor never became starved for fuel.<br /><br />Figure it's the carb or high speed jet...but since the float level has led to improvement, maybe I should keep on "bending the tab" till it nearly leaks when primed???<br /><br />Is that ok, any ideas? Thanks
