Re: joe reeves, dhadley,or ? 120 timing question
Rebuilt all 4 carbs, had heavy float and cracked fuel hose on #2 did sync and link. Took the boat out, put under load, very little adjustment was needed on wot and idle timing was off 2 degrees. All said and done with the cam roller indicator lining up where it belongs motor is idleing in gear at 650 rpm. It hasn't ran this good in years. Thankyou for the help.
