1st_boat_need_help
- Aug 27, 2005
- 5
This is my first boat and I'm trying so hard to get out on the water. The engine runs great until you put it in gear. I've taken it on the water and it will go 5 mph and then its like something isn't catching in the gearbox. Half to full throttle will make it die. I've tried taking the lower unit off and the shaft wont budge! I loosened everything. Its very frustrating. I think the teeth on the gears are worn down but cant get to it, not that I can find parts anyway. I want to fabricate something if that is the problem. Any help or suggestions would be muchly appreciated. Thank You, Mark
