I have a 6hp 1990 evinrude. which I can't get started. I am getting spark and motor will run with fuel mix sprayed into carb. I don't seem to be getting fuel to the carb. I have a new fuel pump. should I get vac at the fuel pump port,on the crank case if I turn the fly wheel by hand?
