This is an Evinrude engine.<br /><br />My 115 will start but then dies as if it has run out of gas. I put fresh gas in the tank, and a new ball to ensure that clean fuel was flowing. I also replaced the fuel pump. Still same result.<br />If I spray starter in the air intake the engine will run until I stop. Also if I use the key to keep choking the engine it will run until I stop. It seems that fuel is not flowing into the carbs.The carbs were rebuilt last year (after nearly 10 years of running fine). <br />The boat is not used very often.<br /><br />The only odd thing I noticed is that it is particularly difficult to get the ball hard. This is why I replaced it, yet it takes a lot of pumps to get it hard and sometimes it (the ball) actually suck in on it self and I have to wait a little while for it to regain its shape for pumping. When I disconnect the fuel line at the connector I can squeeze the ball and get a good flow of fuel.<br /><br />Before I take it in for another overhaul (last year) can anyone offer any suggestions on something I may not have thought of.<br /><br />Thank you<br />drjulian
