  #1
Old February 13th, 2006, 05:10 PM
slcstein@comcast.net slcstein@comcast.net is offline
Default 2000 225hp evinrude ficht fuel starvation? no ck eng light
I have a 2000 225 ficht that seems to starve for fuel.With key on engine off, fuel pump runs until system has pressure. Engine starts right up & idles great & will run okall the way up to 1500 to 1800 rpms with no problems.If engine is taken to up to 2000 rpms it seems to take about20 seconds or so & then starts missing or starving for fuel. Or if given wide open throttle, missing or starving happens almost imediately. No check engine light comes on. I've replaced the fuel filter\seperator under cowling & took fuel line loose from remote fuel\water sperator & put fuel line from primer bulb (tank side) into a remote tank with fresh fuel as to eliminate all components up to the primer bulb. Problem still occurs. At first problem was intermittent, but now problem is constant. Also noticed one time while attempting to run at wide open throttle, ran engine until it stalled. Noticed on restart that fuel pump ran for a while (5-7 seconds) with key on engine off.I thought that might be a sign that fuel system was no longer pressurized after engine stalled leading me to belive that engine was indeed starving for fuel. Once again engine restarted with no problem & would run fine up to 1500 to 2000 rpms.Could this be a lifting pump, reservoir pump, primer bulb or something else all togehter? Any help would be much appricated. Also fuel pump made strange noise earlier in the day beforeproblem became constant.Thanks in advance,
  #2
Old February 15th, 2006, 06:40 AM
DJ DJ is offline
Default Re: 2000 225hp evinrude ficht fuel starvation? no ck eng light
Start with the simple/cheap stuff first.1. Primer bulb.2. Try an all new set up from a REMOTE tank.
  #3
Old February 15th, 2006, 06:56 AM
Cricket Too Cricket Too is offline
Your fuel pump should run like that every time you turn your key to the ON position, same as in your car. I don't really think that indiactes anything. But it making a strange noise at one point might.
  #4
Old February 16th, 2006, 12:36 PM
seahorse5 seahorse5 is offline
On an injected motor like yours a fuel or an ignition problem can sound the same.Hook up an EFI automotive pressure gauge to the Schraeder fitting and run the boat. If the pressure drops off, you have a fuel delivery problem. IF it stays constant, chances are it's ignition. You can find out real quick using a timing lite on each plug wire. You can also use a timing lite pickup around 1 injector wire to test for elelctical operation.There is a 40 volt system that could be out of whack not providing enough power to the ignition and injector systems as the rpms increase. Follow the service manual for troubleshooting.
  #5
Old February 16th, 2006, 06:16 PM
thanks everyone,seahorse, do you know if faulty spark plugs could cause this? it does feel like an ignition misfire, but the thing that's throwing me off is if you go from idle to 2000 rpm it will notmisfire until running at 2000 rpm for about 20 seconds andthat is consistant each time going from idle to 2000 rpm.if rpm is kept between 1500 to 1800 misfiring does not occur.that was making me think it was running out of fuel shortly aftertrying to maintain 2000rpm.I had the spark plugs replaced. i'm going to go for a ride saturday & see what happens. I'll take a fuel pressure guagewith me, Do you know how many psi of fuel FICHT run at? Now, using the timimg light around each plug wire, am I tobe looking for the strobe to flash (or not flash) to indicate a misfire in that cylinder? And does that go the same for injector wiring?
  #6
Old February 16th, 2006, 09:17 PM
Make sure you use the correct numbered sparkplug and gap them about .028". They also have to be indexed correctly. http://www.boatsetup.com/PlgIndexing.html I'll bet the exhaust sensor tube has never been taken out or checked for plugging with carbon. Just follow the small rubber hose from the EMM down to the stb. side of the exhaust adapter and remove the tube to inspect.Fuel pressure should be about 22-30 psi and it should hold pressure after about a 5 psi drop when you turn the key off.
  #7
Old February 17th, 2006, 06:07 PM
if the exhaust sensor tube is plugged up, should it be replacedor can it just be cleaned?
  #8
Old February 17th, 2006, 06:51 PM
If it's plugged solid, replace it. Most of the time the end in the exhaust stream is pitted and corroded, too.
  #9
Old February 22nd, 2006, 08:47 AM
WELL, I WENT FOR A RIDE & HOOKED UP FUELPESURE GAUGE, 20 - 22 PSI UP 1500 RPM, THENWHEN GOING TO WIDE OPEN THROTTLE 0 PSI OF FUEL PRESURE, PUMPED PRIMER BULB LIKE CRAZZY THENRPM'S PICKED UP AND ENGINE RAN GOOD . DOES THIS SOUND LIKE A LIFT PUMP? NOTE: FUEL PRESSURE GUAGE WAS NOT ON AT TIME WHEN PUMPING BULB, SO IDID NOT GET FUEL PSI READING WHEN RUNNING GOODAT HIGH RPM.
  #10
Old February 22nd, 2006, 10:17 AM
Could be a lift pump or even electric pump, restriction or air leakage in the boat's fuel lines, and/or plugged fuel filters on the boat and on the engine, or a combination of problems. Now that you know it's fuel starvation, the troubleshooting begins.Did the gauge hold pressure when the key was turned OFF?
  #11
Old February 25th, 2006, 02:56 AM
I HAVE USED A REMOTE TANK WITH FRESH FUEL& CONNECTED IT DIRECTLY TO THE "T" FITTINGTHAT GOES TO THE LIFT PUMP. PROBLEM REMIANS.FUEL PRESSURE DOES HOLD AT APROX 20 PSI WITH KEY OFF. ALSO NOTICED WHEN IDLING FUEL PUMPIS WHINING, IF PRIMER BULB IS RAPPIDLY PUMPED, WHINE FROM FUEL PUMP WILL GO AWAY FOR A WHILE.THIS LEADS ME TO BELIEVE THE LIFT PUMP IS NOT SUPPLYING THE VOLUME OF FUEL NEEDED FEED THE ELECTRIC PUMP. IS THIS A CORRECT ASSUMPTION?THE FUEL FILTERS/WATER SEPERATORS ARE ALL NEW,ALL FUEL LINE CLAMPS ARE TIGHT.
  #12
Old February 25th, 2006, 03:04 AM
A bad lift pump is logical according to your description. Be sure to change the fuel filter also. The fuel pump, regulator, fuel cooler cannister is an assembly and that could be faulty too.Don't lose sight that there may be more than one problem with the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Year 2000 225 Evinrude Ficht No Oil light doug brander Johnson & Evinrude Outboards 3 August 14th, 2007 08:51 AM
2000 225hp evinrude ficht fuse #1 doug brander Johnson & Evinrude Outboards 0 August 23rd, 2006 06:35 PM
2001 Evinrude 225hp Ficht starting problems FishPharma Johnson & Evinrude Outboards 7 November 15th, 2004 04:39 PM
Evinrude 115 RAM ficht 2000 fuel problem JACQUES Johnson & Evinrude Outboards 0 June 26th, 2003 02:56 PM
2000 Merc 125 Fuel starvation issue Wink Mercury & Mariner Outboards 4 February 9th, 2002 08:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
