Runs great, no problems one day, next day alarm goes off after about and hour of running. I stop engine and restart to turn off alarm. Alarm stays off at low speeds until I up the throttle. Pee hole is fine, engine runs great. I had my mechanice check thermostate and impeller, everything just fine, runs in temp specs. I have also had carb rebuilt. I understand a solid alarm is either 1)overheating or 2)fuel flow. Could it be a faulty sensor? Should I just cut the tan heat sensor wire to the controls? Are there symptoms of reduced fuel flow? (It always is running great when the alarm goes off). Any help would be GREATLY appreciated.<br /><br />P.S. should I be running a 50:1 ratio with this engine? Thanks
