Rattle-
- Aug 16, 2004
- 172
I just finished installing a new impeller in my '76 Johnson 9.9. Since I've never had an outboard apart, it went pretty well. However the two chambers on either side of the water-pump seemed to be pretty thick with oily crud.<br /> When I was removing the top cover of the water-pump to get at the impeller, I noticed the previous owner had reversed 1 of the long screws for a short one. I was wondering if this would have been an on-going problem with all the oily residue in these chambers?. I put all 4 screws back in the proper holes when I installed the new impeller. Should I clean these chambers with some solvent, or something, before I put everything back together. And one other thing...<br />should a sealant (silicone) be applied to the joining faces of the lower, and upper unit before I bolt everything back together.<br /> Thanks for the patience<br /><br />Kerry
