Re: vacum line help
Ah, a mix & match deal. OK, you have a couple of options.<br /><br />Run a line from each of the one-way valves in the intake (thats the brass nipples you mention -- most likely they're plugged so we need to clean them or replace them) to a by-pass cover. Run #1 intake to #2 cover, #2 to #3, #3 to #4 and #4 intake to #1 cover. Actually it doesnt matter where they go as long as its not to the same cylinder. Then cap off the nipple behind the throttle linkage going into the crankcase.<br /><br />Or run any line to the crancase cover and cap off one nipple on the by-pass cover.
