1975 Johnson 70 hp
nscoope
Having trouble going from nuetral to Fwd or Rev.Seems to be fuel problem but have changed/eliminated : carbs(rebuilt), all hoses, tank,... thought I had it solved once, had found a leaky hose to # 2 carb...ran good for a short while, until I ran out of gas...made short trip with new tank and then had problem getting to slow idle...i.e. it would die whenever I tried to come out of fast idle...that's when I rebuilt the carbs, changed the hoses, and now back to problem of not being able to get into gear...any ideas?/
nscoope
Re: 1975 Johnson 70 hp
Tks...my manual only goes to 1972...have another on order...any hints on the sync/link?
papasage
i think the 72 and 75 has the same carb setup.it has 3 carbs. just like the ones on 72. the 72 is 65 hp no 70 hp in 72
