Re: Rectifier compatibility?
I am under the opinion that it will, if it fits the hole. There are many different water cooled rectifiers since they were used. On looper motors they have a different hole pattern then other motors. This being said they also are not all the same. The hole pattern is 5.0 inches across the outside holes on all,then the inside holes are 2.0 apart from eachothere but 2.5 inches across on V4 loopers and 2.875 on most others. Ok now there are 3/6, 3/10, 35 amp rectifiers regulators. Ok I can't tell the 3/6 or 3/10 apart from each other but the 35 amp has a large red wire 8 gage as oposed to the smaller ones having a looks like 14 gage wire. The 3/6,3/10 means at idle they only can provived 3 amps of power but at 4600 rpms they can provide 6 or 10 amps of power. Ok you need to see if yours was a 35 amp model or other I am guessing its a smaller one. Just look to see if the hole pattern is the same. Then look at your ussage of power. I just changed a 35 amp for 3/10 amp unit with the same hole pattern and I have no problems. They all have part numbers stamped on them just post your number and the one you want to use I have researched them all I will let you know.
