Re: 69 55hp amplifier conversion
I have a 1969 85hp Johnson with points and CDI ignition system, so I'm always interested to read about this stuff.<br /><br />I recall someone mentioning in a post that the points for this early CDI system could be expected to wear out faster if you converted to the automitive style ignition system. I don't know myself as the amplifier on my engine is still working, but I doubt I'll be spending the $400 bucks for a new one when it dies.<br /><br />In the few posts I've read about this conversion, I don't think there has been much talk about Ballast resistors. If you're using a automotive coil that's intended to be used with a ballast resistor, and you don't have the ballast resistor in the circuit, you may be frying the coil. <br /><br />Coils designed for seperate ballast resistors are designed to operate below 12V, not at, or above 12V. This may be further agrivated by the poor voltage regulation on some of these motors. I don't believe my 85hp has a real voltage regulator at all.<br /><br />Perhaps someone else can add a comment about automotive coils and ballast resistors? <br /><br />Sean
