72 65hp johnson 3cyl......could bad timing blowout a head gasket?
FreeBase
This motor had been running great all this spring and early summer. Then, my timing advancer stop lost it's jam nut and the timing was all out of whack. Probably ran it for five minutes before I realized the problem. I then took the boat out with my buddy and a timing light and reset the timing at 22 degrees(johnson spec), and it seemed to run fine for a while, but started to get worse again. Now, I've got wet spark plugs, and also, when I put earmuffs on the motor to test run, the cyls fill with water! Could bad timing have blown the head gasket causing the problem?
Goodoleboy
Re: 72 65hp johnson 3cyl......could bad timing blowout a head gasket?
I dont beleive timeing can cause it. Blown head gaskets are usualy the result of over heat. <br /><br />Causeing head and block worpage. Heads bolts not torqued corectly can also do it.<br /><br />Perhaps carbon build up causeing hot spots and resulting in detnation could build enough pressure to blow gasket before piston gave way.<br /><br />But just timeing being off, And causeing blown gasket with all other things being correct. I dont think so.<br /><br />Good luck!
