Re: high rake prop?
PH, had a simular problem on my 16 alum after installing a jack plate. What worked the best for me (allowing me the most height) was a michigan wheel that a machinist put about 25 degrees of cup in for me. It was a 10x16. It was the perfect prop for my boat, I say was because I destroyed it and so far have not been able to duplicate it.I am running a 10x15 hustler for the time being, and would not recomend this prop. Also I need to tell you that I installed smart tabs which will make a remarkable differance to you especially, with all that weight hanging off the end of your short little boat. Mine is a tiller also so beleve what I'm saying, with you,the Mtr and that t/t unit back there, the tabs will make a heck of a differance. One of the props you have now may work after the tab install, if not take one to the prop shop for some rake.
