Model E200TXES VRO- it is pumping fuel, vacuum switch activates at 12/13 inches, will run at fast idle as long as you keep activating electric choke w/key, new filters, no air leaks from tank past pump, bubble pump stays hard while running sometimes, new plugs and wires, new electronic box,cleaned fuel line and no debris or water found, and when it is running engine shakes at lower RPM range[1200-1750]. Waiting on books and it just started doing this on second trip out. Ran very good on first trip and halfway across Chesapeake Bay. Lost 1000 RPM on return trip and wouldn't make it back. Also it has a 85 gal in boat tank, vent is open. Removed pickup tube from tank and no visable problems seen?????? Anything I Missed???
