bonanzaDarryl
- Jul 21, 2005
- 9
I have a 1980 johnson 60 hp.2 cyl. this will be the 3rd leg put on. Is this just 2 times lucky ??<br />- bought boat 3 years ago motor ran well but the lower end was gone. said they had hit rocks etc. (young guy)<br />-purchased a so called rebuilt leg installed it and used it for 5 -6 times. it also went, motor runs fine tore down leg and gears were gone.<br />only thing that happened was in towing up a drive way the motor was down and the leg hit the pavement hard enough to break off half the fin. <br />could this have resulted in failure?? moter ran the 5-6 outings after that fine untill BOOM..<br />(drained oil it ran green no water contamination. there was about a liter or better that i drained.)<br />I have purcased a used lower leg again and will install this week. Does this engine have a bad track record for failure.. was it a johnson lemon? or will it fail like that with a hard hit on bottem of leg.. does this hurt motor?? the end oh the drive shaft(splines) look fine no signs of stress..
